Where are the cables in creo view?
vincecatlin
The connectors are shown but NOT THE CABLES.
7 REPLIES 7
Vince
What versions are you running?
thanks
Jim
We have 10.1 Datecode 010
And what version of Creo?
We've got Creo Parametric 2.0 M150
Vince
I have just tested exporting a cabling harness using creo 2.0 M170, using file > save as > PVZ, and the cables appear without any issues.
See attached file
thanks, Jim
That's understandable. I saw this yesterday so it looks like we just need to change some settings in the "recipe"
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS162681&art_lang=en&posno=1&q=cables&ProductFamily=Creo%20View%20%26%20Illustrate&source=search
Hello Vince,
this is a good finding and I assume it solved your issue (otherwise we would probably have heard back from you).
Hence I will mark your post as Correct Answer to indicate that this thread has a solution.
Gunter
