If I publish pdf and change element is put under page header, change word (Změna 1) in page footer is displayed incorrectly (twice). If change elements are among page header and footer or text of change element starts on first page and ends on second page, change word in page footer is displayed correctly (once).
I use Arbortext Styler 6.1, FOSI engine
RichK
Hey Richard,
Did you end up opening a case for this with TS? Seems like that may be the best route to go for something of this nature, unless you want the Community parsing through your FOSI. Let us know if you resolved it, and how, if this is no longer an issue for you. Thanks!
The problem was resolved.
