How do you configure creo to use Firefox instead of IE11
Drake,
you can set Firefox (special version included in Creo installation) to be used by Creo Parametric 2.0 in embedded browser window.
Add the following option at the end of your config.pro file:
WINDOWS_BROWSER_TYPE MOZILLA_BASED_BROWSER
Martin Hanak
