I have an FTA tree with a repeated "undeveloped event". After researching and entering the correct failure rate, I would like to change all instances to "Basic Event", however, the Gate/Event Type column is grayed out.
Dustin
Dustin,
you will have to disable the "repeat" attribute first, and then change from undeveloped into basic accordingly.
Finally, re-enable the "repeats"
Thomas
