trailing zero's
cdown
trailing zero's
In wildfire what is the DTL config to show trailing zero's?
Also the config to have a limit dimension to be one above the other?
BenLoosli
23-Emerald II
(To:cdown)
This is from the Help Topic Collection for WF4 in the Detail.pdf. Everyone should download these documents for reference!
lead_trail_zeros
Controls the display of leading and trailing zeros in dimensions.
std_default*—Displays only trailing zeros. No leading zeros are displayed.
std_metric—Displays only leading zeros. Trailing zeros are not displayed.
std_english—Displays only trailing zeros. Leading zeros are not displayed.
both—Both leading and trailing zeros are displayed.
Also, ASME Y14.5 does not allow the use of trailing zeros for tolerance place holding if you are using metric dimensions.
BenLoosli
23-Emerald II
(To:cdown)
lead_trail_zeros
