Plotting by pcf file turns drawing 180°
MichaelHacker
7-Bedrock
Hi all,
I have a little Problem with my pcf file. When I use it everything on the drawing is fine but it is turned 180°.
If I use MS_PRINT_MANAGER instead, everything is fine
This is a Problem because printing A3 and A4 I can normaly take the package of paper and clip it. In my case I have to turn all A4 drawings and then go to Clip the papers
This Problem is only with size A4 with layout Portrait. landscape is working fine. Also minimizing A3 on A4 is working fine when layout is landscape.
pcf-content:
plotter MS_PRINT_MGR
button_name A4_TEST_MJH
button_help A4-Zeichnung auf Standarddrucker drucken
interface_quality 3 default
pen_table_file xxx\pen_table.pnt
paper_size A4 default
paper_size_allowed A4
plot_translate 0 0.2 MM
Michael.
default ms_print_mgr.pcf contains following lines:
plotter ms_print_mgr
button_name MS Printer Manager
button_help Print using Windows Printer Manager.
The main difference between your pcf file and default one is:
I guess that 180 degrees problem is related to the following line:
When you print A4 portrait drawing created in Creo Parametric 2.0 you will get:
Test two variants in your pcf file:
paper_size variable 297.000000 210.000000 mm
-OR-
paper_size variable 210.000000 297.000000 mm
Martin Hanak
Martin Hanák
7 REPLIES 7
TomU
(To:MichaelHacker)
Printing in Creo has issues.  Lot's of issues.  Especially portrait oriented sheets.
Try changing the paper size to "Custom" and use the long side dimension as the height and the short side as the width.  Then leave the orientation set to "Landscape".
(In the past, "Landscape" really meant "don't rotate" and "Portrait" really meant "rotate 90 degrees".)
Note:  The above is based on Creo 3.  It may or may not apply to Creo 2.
Michael.
-OR-
Martin Hanak
Martin Hanák
pcf as follows is working:
pen_table_file S:\ptc\02_CAD\01_config\eplplot\pentables\pen_table.pnt
paper_size variable 210.00000 297.00000 MM
!paper_size_allowed A4
plot_translate has to be edited according to printertype
you might also try if this pcf-option has any influence:
rotate_plotting yes / no yes – Bewirkt beim Plotten das Rotieren eines Postscript-Plots um 90° gegen den Uhrzeigersinn (Hochformat).
Die Horizontale auf dem Bildschirm entspricht der kurzen Kante des Papiers.
no – Postscript-Plots werden nicht rotiert.
Beim Plotten von Teilen und Baugruppen wird das Querformat vorausgesetzt.
Die Horizontale auf dem Bildschirm entspricht der langen Kante des Papiers.
rotate_plotting option is related to Postscript output, only. I does not affect print via Microsoft Printer Manager.
MH
Martin Hanák
I would give it a try anyway. Even if it was described just for PS-Files.
didn't work at that Point, was one of my first ideas.... but thanks anyway
