suggestion for improvement for preselection highlighting
ograf
3-Visitor
status at the moment:             You want to create a feature and therefore you need references. You move over the the model with the mouse.
Creo highlights the geometry elements in the back, points edges etc. but not the surfaces you look directly in front of you.
This is not logically!
suggestion for improvement:
1) The preselecting should be done on geometry, which is in the front you look at it. And this also first to surfaces.
2) in the environment you can set up the menu preselection highlighting with choose from filter and my filter!
                     It would be very helpful if it you could set a order with ranking. To move filters e.g. egde, up or done "stairs"
    That you can do your own setup order for preselection
A bit like this, you mean?
Improve selection sequence
Please vote for it if you have active maintenance!
yes. like this. But with new idea for filter order!
PTC should update this with modification-programming software.
