How are you managing font distribution to users PC's?
shumphrey
6-Contributor
We don't have a large number of users, so in the past I've just copied the font's to each PC.  I was curious what other methods people have been using.
Sandra
I have a central server location for all "common" files and startup scripts that are read only
I let the config.pro options locate those directories.
makes it easy for administration if there is a change/update
My setup:
then I map accordingly
ron
We handle it very similarly to what Ron is doing.  +1
-marc
