To community:
The attached worksheet shows two programs.
The one on the left shows one way of repeating a calculation that works and accomplishes what it is supposed to do.
The one on the right is an attempt to0 do the same by iterating the calculations but only goes into a recursive mode.
Would like help in the proper programming procedure.
Thanks for any help
Dick.......
Have you not already asked this question here:
Solved: Re: Iterative Programming - PTC Community
Mike
