I tried to print to PDF an educational worksheet and this is the result.
Am I missing something?
I don't see the same problem. Maybe it's related to the language settings. Try a different pdf printer. I use CutePDF. It seems to be very reliable.
What PDF printer you use and can you provide this Prime worksheet?
I did a disaster attaching the file, sorry.
This is the worksheet.
I'm using the default printer of mathcad, I guess.
I think it's a font problem.
Do you have the 'Tahoma' font on your system?
I also recommend you to use "CutePDF Writer": CutePDF :: Product :: CutePDF Writer
Thanks all for your responses. The problem was solved using CutePDF.
Thanks!
