Truncate parameter in a format repeat region
akok
11-Garnet
I will like to in a table on a format having the PTC_WM_CREATED_BY shown, but only the initial.
Can I on my format in the Repeat region use a relation to truncate this parameter, I have tied the relations in the Repeat region menu, but can't get it to work.
MartinHanak
24-Ruby II
(To:akok)
Allan,
here is my "procedure":
  1. I opened the drawing containing repeat region table with relation
  2. I saved the table as rr_table.tbl
  3. I created new format and imported table from rr_table.tbl
  4. I saved format
  5. I created new drawing ... in dialog box I selected drawing model and drawing format
  6. new drawing now contains requested table
MH
Martin Hanák
MartinHanak
24-Ruby II
(To:akok)
Allan,
is the following example describing correctly your need ?
PTC_WM_CREATED_BY="Martin Hanak"
PTC_WM_CREATED_BY_TRUNC="MH"
MH
Martin Hanák
Martin,
not really.
I have in the filter "&mdl.param.name  == PTC_WM_CREATED_BY", and that give me the full name.
In the relations I have tried "truncated = extract(mdl_param_value, string_length(mdl_param_value)-10, 3)", this give not error, but not change anything. If I use PTC_WM_CREATED_BY, comes an error "PTC_WM_CREATED_BY is unknown".
What shall I put the filter and in the relation?
Allan
MartinHanak
24-Ruby II
(To:akok)
Allan,
below written procedure is related to my data created in CR2 M070.
  1. I "informed" repeat region about existence of MY_PTC_WM_CREATED_BY parameter, this means I selected table cell and clicked asm > mbr > User Defined and entered MY_PTC_WM_CREATED_BY
  2. I updated table ... see result in upper table on my drawing
  3. I created the same table once again ... see lower table on my drawing
  4. I added relation ... TRUNC_MY_PTC_WM_CREATED_BY = extract(asm_mbr_MY_PTC_WM_CREATED_BY, string_length(asm_mbr_MY_PTC_WM_CREATED_BY)-10, 3)
  5. I replaced the contents of table cell in second column, I removed &asm.mbr.MY_PTC_WM_CREATED_BY and entered &rpt.rel.TRUNC_MY_PTC_WM_CREATED_BY (it is also possible to click rpt > rel > User Defined)
MH
Martin Hanák
Martin,
I can get your description to work on a drawing, but on a drawing format then I will create the relation my parameter is not known. And therefore I get an error. How can I fix this?
Allan
MartinHanak
24-Ruby II
(To:akok)
Allan,
  4. I saved format
MH
Martin Hanák
Martin,
Thank you it's working.
Allan
