I am adding reference text to extruded parts i have created, how do i embed the sketch with the text to the extruded part?
see print screen of model tree for example.
I am using CREO2 if this helps?
Thank you for any help in advance.
Ankeet,
Could you confirm that after reopening the drawing, format is there in drawing? Possible reason for this is missing format on reopening the drawing.
I did not get what you meant Mahesh.
The problem i am facing is that the projection angle symbol i created in the title block in format platform.
I created the title block using the normal table option that we have. But i made the projection angle symbol using the sketch feature.
So i do save my work and close CREO, next time i open i find only the projection angle symbol disappear.
I have noticed that other that the projection angle symbol all the other elements in the title block is blue. Projection angle symbol is black.
the different color is no problem. It's just that letters, table lines and 2d elements have a different color.
If the suggestions of the others haven't helped you so far, I'd recommend the following:
- Mark you symbol features and select "draft group" and enter a name for it. This makes further handling easier.
- Save your format file per "Save as / save a backup" to a different location, load excatly that for your next try.
- Otherwise you may have to check whether "pro_format_dir" is set and to which location you actually read from and write to.
HTH
Questions to ask:
Where (file location) am I storing the changed format file?
Is this location the same as my working directory?
If not, then you need to either save or download the .frm file in the working directory
