Hi All,
I am going to search Parent Part from Windchill, by providing a child part as an attribute to a program.
which method i have to use for getting Parent information from child.
How i can navigate in structure from bottom to Top.
Any help will be grate.
Vivek
I think you can use wt.part.WTPartHelper.service.getUsedByWTParts(WTPartMaster partMaster)
Thank you,
Binesh Kumar
Hi Binesh,
I am also looking for similar kind of solution to be used within a Validator.
I will have to hide an action when the value of an attribute on Parts Usage link is true.
If I use the above said API, I would all the parts that are being used in all the BOM's is there a way how I can get its immediate Parent from the structure?
Is there a way to achieve this?
