when the engineer duplicates a part, he didnt duplicate the drawing. in Intralink, there was a work around, where i could duplicate the part and drawing, then update the part in my workspace, with what was in commonspace. how can i do this in Windchill. i tried it, but it fails because the part exist in common space.
Engineer duplicated a part, with a new part number, but didnt duplicate the drawing with it. so, i have to go redimension the drawing because he moved a hole.
thanks for your help.
One way is to do this:
I will try that.. now.. quick question, how can i open a non linked session of creo? is that work offline? can i do this with my linked session running?
From the Server Management dialog activate "<NO SERVER>":
This exact same process still exists. We use it every day. You may need to enable the preference in CS94283.
thanks alot, i will post up a follow up, when we do this again, as im sure it will happen.
