Considering mathcad A very powerful calculation tool, I can not accept that in calculating the Laplace transform of the square root of t square, + a-squared, I have to resort to the tables. One can not intervene in some way, for example giving the user the possibility to expand the set of transformed?
Thanks for the attention
Yours sincerely.
F. M.
Try please
Hi ! in fact I do not understand what you want me to say.
All I know is that those results are incorrect.
But I have never encountered such problems as you can see in my documents in the "electrical engineering", where I make extensive use of the Laplace transform.
Hi Valery!
Not sure what you are doing here.
I don't think, that laplace is broken in Prime. It looks to me as for some reason your variable t is not seen as the independend variable of the transform, so f(t) in both cases is treated as a constant. Not sure why - maybe t is defined otherwise above or its again one of the many problems which arise in Prime because of wrong (automatic) labelling of the variables.
Anyway, there is no problem in Mathcad 15 and I guess it should work the same way in Prime, too, if you label t manually yourself.:
R
Mathcad 11:
Internet...
Are you sure your transform is correct? (Can you prove it...)
...And Maple 18.
Viktor
Hi, Viktor Korobov! The correction is right, but not the answer I'm looking for.
Greetings
F. M.
Do you know that engineers use (used) slide rules, sorry, logarithmic rule with base 10 but mathematics - with base e (2.71828)!
Joke!
But seriously, the slide rule of algebra is the Laplace transform, which replaces the taking of derivation on multiplication and taking the antiderivative to the division. A Normal slide rule replaces multiplication by addition and division on subtraction.
Prime
.... ah! ah! ah! do you want to imply that the ruler and mathcad .......... ........... are almost equivalent?!?!?!?
The ruler, now, is part of the history of mathematics and engineering, I keep it only as a memory of my youth ... I do not remember even how to use it ...
Greetings
Greetings
and Laplace transform too "is part of the history of mathematics and engineering"
......Is already! this is all nice and ready ...
The second transformed must be corrected as follows:
I needed only the first of the two transformed, as I know to be correct. The second transformed, now is
correct.
Bye
Thank you for pointing out the inaccuracy of the second L-transformed. In fact the second term at the second member of the transform (in the list of the transforms) is written at the head, which I had not noticed. Thanks again for the tip.
With best regards,
F. M.
