Is it possible to use loadFromFile to load ad-hoc acl?
yigu
7-Bedrock
I am trying to set access permission for each folder, however, it would be very time consuming using GUI.
Is there a way to load ad-hoc acl like load "normal" access permission?
btw, I am using 10.1M050.
Many thanks
BhushanNehe
(To:yigu)
Hi Yifu,
I doubt if there is any loader for Ad-hoc ACL's . Are you using PDMLink or ProjectLink? There are also other options like associating domain to a folder and having separate set of access permission defined on that domain.
Bhushan
Hi Bhushan,
Thanks for the reply.
I'm using PDMLink. Associate different folder with different domain is indeed a good idea, however, the sub domain will inherit permission from parent domain, which makes me cannot think straight.
A
┣B
┗C
This might be childish, if I want to let a user/role can only access folder C through A, and keeping B invisible to user. What is the best practice of settings in Windchill?
Many thanks,
Yifu
BhushanNehe
(To:yigu)
Hi Yifu,
Are you simply trying to hide folder B to users or even the content. If you hide folder B by not granting Ad-hoc permission, I believe the objects in folder B would still be searchable if users have Read permission on those objects.
Bhushan
Yes, that's true. I should re-think the whole thing. Thanks for the help!
LoriSood
(To:yigu)
Going back to the idea of changing folder domains, you can always override the parent domain permissions by specifying explicit Deny permissions on the necessary object types in the sub-domain. Will that work for you?
yigu
7-Bedrock
(To:LoriSood)
Deny permissions would be the solution, just personally not want to use deny permissions. Thanks!
