Here's a brief overview of the situation;
We have 4 licences in total at the moment, two for IsoDraw 7.1 with CADProcess and the other two for IsoDraw 7.1 Foundation, running from a licence server, the problem currently being experienced is that we cannot open IsoDraw 7.1 in foundation only mode because it defaults to opening with CADProcess thus not allowing computers to run the foundation licences.
Could the problem be caused by the command line used to launch the software (missing command, etc.)?
Command Line: C:\Program Files (x86)\PTC\Arbortext IsoDraw 7.1\Program\IsoDraw71.exe
==Edit 05/02/2016==
Stated in the screen capture below, newer versions of IsoDraw (7.3) allow you to choose which one is activated from inside a UI, while in older versions (such as ours) the command line was apparently the only way to set the licence options.
This is why I think a modification to the command line above could fix the problem we face, does anybody know what that modification would be?
Robert Edkins
