SDK in Creo 3 Trial
qazerty
SDK in Creo 3 Trial
Hi All,
In the Trial version of PTC Creo, where is the Software Development Kit ?
Where can i find it?
I want to use the VB API.
I assume you're talking about Creo Parametric 3.0, which does have a Visual Basic API.  I currently have Creo Parametric 3.0 Build M070 installed, but it's not a trial version. I don't know if PTC offers the VB API with trial installation disks.
I have the Visual Basic API is located under
Common Files\vbapi
As I remember, this was an optional module when I installed it.
|+|  M a r k  |+|
Hi.
Yes i talk about Creo Parametric 3.0.
I dont' have "vbapi" folder and in my setup I did not find the option to install the VB API.
Do you have any idea?
You'll need to ask PTC about this. You should tell them that you want to include the Visual Basic API as in your evaluation of Creo Parametric 3.0.
|+|  M a r k  |+|
