Hi
i want to create new layer and want to add new datum planes (which i have created in model) to this layer, i am able to create layer but the entities are not moving to this layer.I have tried it for both two ways-
1. ADDING PRT_LAYER DEFAULT_DATUMS NONE LIST_DEF and writing
LIST_DEF DTM1
LIST_DEF DTM2 (in the start file)
This only adds the layer to the model but not inserting both datums to the layers.
2.ADDING PRT_LAYER DEFAULT_DATUMS NONE LIST_DEF and writing
STD_USER_LIST_FILE text\LIST_DEF.txt ( in the start file)
but the items are not inserted to the layer.please provide solution
a recent discussion on the topic of layers that may shed some light
Is there a simple way of only showing a few planes in assembly mode.
Ron
