Greetings from Arizona,
Is there a Symbols Legend that identifies the cursor symbols?
So when I see a red circle with a green minus sign, I can understand what that means.
I’m know there are other symbols as well as the one I am searching for listed above.
It would be nice to know what these symbols mean will using Creo Schematic.
Respectfully,
- Patrick
