Adding cable location points after upgrading to M190, doesn't work?
riaea
2-Guest
We ran across an issue. We just recently upgraded to Creo M190 build and we noticed we can't add location points to routed cables!
Any ideas? Is this a bug or a config parameter issue?
gkoch
(To:riaea)
Selecting cable and RMB > Insert Location is not working in Creo Parametric 2.0 M190?
Strange!
I did not find any reports of such an issue in our database.
Have you checked reference scope in this assembly - maybe it is interfering with feature creation?
