How to create numbered chapters and sub-chapters in prime3
pklemm-2
6-Contributor
I have to create a large matcad-document under prime 3 und want to devide it into numbered chapters. Is there something like a MS-Word chaptering, so that an insert between existing chapters would renumber the old chapters.
Or what is the preferred method to get numbered headlines?
MJG
18-Opal
18-Opal
(To:tietjee)
Thanks David.  Do you often use this?  Does it slow down the Mathcad file?
Peter, David was providing the Mathcad 15 solution per my request.  No one has a solution for Prime.  If PTC someday adds scripted components to Prime, then this solution should be usable in Prime.  However, the preferred solution would be for PTC to incorporate numbering similar to MS Word.
10 REPLIES 10
StuartBruff
23-Emerald II
(To:pklemm-2)
As far as I'm aware, there is no paragraph/section autonumbering facility in Prime or Mathcad 15.   In Prime, you could try setting a variable and then displaying it and incrementing it at each change in paragraph.  You could try using one of the old Mathcad tricks for hiding part of an expression, such as dropping a "white" text box over the part you want to cover.
Stuart
Note: If PTC don't include the capability in Prime 4 (and I don't think they plan to), then it might be possible to use the planned components to create an auto-incrementing section number (I can do this in Mathcad 15).
pklemm-2
6-Contributor
(To:StuartBruff)
Thank you, Stuart. I feared it...
tietjee
(To:StuartBruff)
The auto number program in Mathcad does help with sequence numbering.  You will have to search the discussion board to find it.
pklemm-2
6-Contributor
(To:tietjee)
I cannot find any numbering solution in Prime3. Could you please give a link?
Would you be willing to share your Mathcad 15 solution?
tietjee
(To:MJG)
See the script "Keeping track of equation numbers"  You can edit the script to add test before and after the number.
pklemm-2
6-Contributor
(To:tietjee)
Thank you, David.
are you sure that this also should work in Mathcad Prime? Is there a scripting engine in Prime3? That would be great.
If I understand it right, the solution is also based on hiding unwanted parts inside a text block. But I cannot find any way to do that in Prime3.
MJG
18-Opal
18-Opal
(To:tietjee)
tietjee
(To:MJG)
I use it off and on, depending on the document.  The script is edit to have table, figures, etc.  Does not slow the program.  PTC will have to add a scripting program to Prime for this to work.
Enjoy
pklemm-2
6-Contributor
(To:MJG)
Sorry, no. Its a Prime3 solution and its a general question then does not depend on my special one.
