Repeat Region Relation
BenLoosli
23-Emerald II
We have the standard bulk item relation in the BOM that sets QQTY to AR if the item is a bulk item part.
I added a second relation that would set the QTY to AR if the number was a certain value. It was a shown item in the drawing, a clamp, that was noted use as many as needed. When I regened the drawing, my item QTY went to AR and the bulk item QTY fields went to blank.
Is there some trick to getting both relations to execute and populate the BOM properly?
Ben
Windchill 10.0 m040
Creo 2.0 m100
TomU
(To:BenLoosli)
Right, The last one wins.  The second relation is changing ALL values back to rpt_qty (except for "TPZ-652").  Just remove the "ELSE" section completely from the second set of relations.  You don't need it.
TomU
(To:BenLoosli)
Can you share your relations?
BenLoosli
23-Emerald II
(To:TomU)
IF asm_mbr_type=="BULK ITEM"
QTY="AR"
ELSE
QTY=rpt_qty
ENDIF
IF asm_mbr_pdm_number == "TPZ-562"
QTY="AR"
ELSE
QTY=rpt_qty
ENDIF
With only the first relation for Bulk Items, all of the bulk item QTY fields go to AR.
When I add the second relation, the QTY filed for TPZ-562 goes to AR and the bulk items all go QTY blank.
TomU
(To:BenLoosli)
BenLoosli
23-Emerald II
(To:TomU)
I like this solution best as it does not need the ELSE clause.
Thank you both for the help.
StephenW
23-Emerald II
(To:BenLoosli)
Yea, what Tom said...the way I do it is by combining all in to one continuous IF
QTY="AR"
ELSE
QTY="AR"
ELSE
QTY=rpt_qty
ENDIF
ENDIF
Although I don't rightly remember if I'm supposed to keep the ELSE in the middle or not...always a little trial and error for me.
TomU
(To:StephenW)
Nested IFs works okay for a limited number of conditions, but if checking for many of them, then I think it's cleaner to keep each one independent.  To each their own!
