The two inverse laplace transforms are exact?
-MFra-
21-Topaz II
By gentleness is there an expert who can tell me if the attached inverse Laplace  transforms are exact?
Thank you very much.
With best regards
F. M.
(To:-MFra-)
This may help you.
-MFra-
21-Topaz II
(To:LucMeekes)
Hallo Luc, excuse me but I don't find satisfactory your reply.
The issue concern the response of an active high pass filter, to a sawtooth signal. I find a discrepancy between the calculated response and that obtained by convolution. for this reason I would like to know if there is an error in the calculation of the response. active filter responses.jpg
With best regards
F. M.
-MFra-
21-Topaz II
(To:LucMeekes)
Perhaps, the calculation details can be useful to better understand the problem. Therefore, I attach a picture about the calculations.
(To:-MFra-)
Your waveform FMSAW is:
The literature gives the following LaplaceTransform | TimeFunction relationship for a sawtooth LITSAW:
That LITSAW waveform can be converted into yours by:
FMSAW(t)=10*(LITSAW(t)-0.5) = 10*LITSAW(t)-5
Further it is known the following LaplaceTransform | TimeFunction relationships:
and
Then I conclude that the Laplace transform of FMSAW(t) = fmsaw(s)=10*litsaw(s)-5*1/s=
Does this help?
-MFra-
21-Topaz II
(To:LucMeekes)
My signal is a sawtooth (bipolar). To obtain the Laplace transform of it, you have to subtract 1/2 to what you provided, ie subtract 1 / 2s to the transform  you provide. Thus obtaining the formula No. 7 of my previous photo. So, your answer, it is not very useful.
in my particular case
... But thank you anyway.
F. M.
