tension plotting problem
mdewolff-2
2-Guest
I'm trying to plot a function from Hibbeler Mechanics of Materials in Mathcad Prime 3.0 but I'm not getting any results.
I put in a figure for P (15N) and for A (100mm^2). So the bar on top of the page isn't rectangular but square (10x10mm)
Theta = 30deg is not producing any result.
Somewhat below on the right I tried to list all theta angles from 90deg to 0deg: no result.
Obviously I do something wrong here. Please help.
Thanks maurits
(I accidentally cross posted in the sub section mechanical engineering. I'll try to delete the cross posting)
RichardJ
(To:mdewolff-2)
You have sin multiplied by theta, but you need sin(theta). Also, do not confuse the different equals. There is the numeric assignment, :=, the numeric evaluation (which displays a result), =, and the boolean equals (which you get with Ctrl =, and is bold), =.
RichardJ
(To:mdewolff-2)
