Hi All,
We are currently working on replacing the older Pro/Diagram logical information with Creo schematic RSD file. But when we bring RSD file into Creo Cabling, older wire information's are not getting replaced by new information when we update all information. This functionality working fine with cables were all the information are getting replaced by new RSD file. Could you please help us on this issue?
Workaround:
1. If we rename wire name manually in 3D cable same as the new wire name in RSD file, then logical Data getting updated automatically while updating the cable information.
2. Rename the wire name in RSD file same as older logical reference then information will be populated correctly in 3D cables.
Thanks and Regards,
Prajesh Hegde
