Hi All,
When we bringing in new RSD file to Creo cabling, wire from and to locations are showing in reverse direction. Is there any way to flip the wire ends in Creo Cabling?
I have tried to use Flip cable ends functionality, but it looks like that functionality will work only for Cables.
Also i have tried to reverse the direction in Creo Schematics and generated new RSD file for the same, but changes are not reflecting Creo Cabling.
Could you please help me on this.
Thanks!!!!
