I am working on one UIValidation where I need to validate the two attributes (customer part number, new customer part number ) of New Document wizard page,
currently I am trying this is on acion=createDocumentSetTypeAndAttributesWizStep but not working can any one please tell me how should I use this
Hi Ankit,
If the action has a afterVK element you will have to register the validator against that. In case of createDocumentSetTypeAndAttributesWizStep you will have to use the setAttributesWizStep and get your custom validator registered.
<action name="createDocumentSetTypeAndAttributesWizStep" id="createDocumentSetTypeAndAttributesWizStep" afterVK="setAttributesWizStep" preloadWizardPage="false" required="true" afterJS="validateDuplicateName">
<command windowType="wizard_step" url="servlet/TypeBasedIncludeServlet?contextAction=createDocumentSetTypeAndAttributesWizStep"/>
</action>
But I guess setAttributesWizStep already has a OOTB validator in place, so you may want to extend that and create rename the afterVK (say setAttributesWizStep1) and register in properties
e.g.
wt.services/svc/default/com.ptc.core.ui.validation.UIComponentValidator/setAttributesWizStep1/null/0=ext.CustomValidator/duplicate
I tried this and it actually called validateFormSubmission from customValidator class.
Bhushan
