Column to column multiply
ranto
9-Granite
How to myltiply single column to column in matched prime like excel
DJF
16-Pearl
16-Pearl
(To:ranto)
I think you mean how to multiply the first two entries by each other, then the next two?  Mathcad will by default give you the dot product of any two vectors.  But if you 'vectorize' the multiplication you get row by row multiplication
You obtain the vectorized result by highlighting a*b, then hit SHIFT+CONTROL+^
ranto
9-Granite
(To:DJF)
Thank you boss
StuartBruff
23-Emerald II
(To:ranto)
Use the Vectorize operator (should be shown under the operator ribbon in Prime). The example below is from Mathcad 15, but should give the same results in Prime.
Stuart
(Note: seq is a user-defined function and not a built-in (although something similar should be!)
thank you boss
