After to insert a image in a cylindrical surface, do you know how to rotate the image??
I have added a creo file, and I want to rotate the image 90°, somebody help me with this issue please
unfortunatelly you model does not contain any picture. Maybe my picture will help you.
MH
MH
Thanks SO Much
Have a nice day!!
Hi Mauricio,
If Martin's reply helped, please remember to mark it as the Correct Answer.
Amit
thanks
Thanks for doing that Mauricio.
