global assignment of maximise value
jzy
hey lads, its me once again. I asked a question regarding the angle beta and it was solved by the awesome individuals from this community. But now I have another problem because of this. I need to global assign this beta value so that my calculations can be automated instead of me manually typing beta every single time! helppp!!!
StuartBruff
23-Emerald II
(To:jzy)
Do you mean global assignment in the Mathcad sense of the word (look it up in Help), or do you just want an assignment to a variable? For example,
Global Definition.
Mathcad performs two passes through a worksheet.  Anything defined using a global definition operator is picked up during the first pass, and anything using a normal definition operator during the second pass.   This allows a variable or function to be physicall defined after it is used, unlike normal Mathcad evaluation.
Stuart
Fred_Kohlhepp
23-Emerald I
(To:jzy)
You can assign the result of a solve block to a variable name.  (See purple in attached.
Sorry for the late reply guys. I forgot to tell you that all my values about have been globally assigned as I needed to put some values for a summary at the front of the mathcad sheet. Thats the reason why I kinda of have difficulty assigning the result of a solve block to a variable name. I cannot globally assign the result to a variable name.
I have had the same issue. My conclusion has been that it is not achievable.
What I do is I create a separate summary worksheet. Then I create a collapable area at the beginning with a reference to the original sheet. Then all results are available for writing a summary. Then I print both documents to pdf and merge them. It is not a really pretty solution so I hope that someone has a better suggestion.
Dennis,
I am guessing that your method is the only solution to our problem. I dont see any method to name a variable such as maximise using global assignment. Any experts have any take on this?
