WBM Loader Installation failure?
sghongade-2
Hi everyone,
Facing the issues with installation  the WBM loader, i installed the wbm loader tool but when i run the command " wbmgen " through windchill shell, it gives me the following error.
INFO  sysgen.SysGen                 - You selected optimization: 1
ERROR sysgen.SysGen                 - An Exception/Error occurred during execution. Please see trace below ...
java.net.ConnectException: Connection refused: connect
  at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
  at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:85)
  at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:339)
  at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)
  at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182)
  at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
  at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
  at java.net.Socket.connect(Socket.java:579)
  at oracle.net.nt.TcpNTAdapter.connect(TcpNTAdapter.java:149)
  at oracle.net.nt.ConnOption.connect(ConnOption.java:133)
  at oracle.net.nt.ConnStrategy.execute(ConnStrategy.java:405)
  at oracle.net.resolver.AddrResolution.resolveAndExecute(AddrResolution.java:454)
  at oracle.net.ns.NSProtocol.establishConnection(NSProtocol.java:693)
  at oracle.net.ns.NSProtocol.connect(NSProtocol.java:251)
  at oracle.jdbc.driver.T4CConnection.connect(T4CConnection.java:1140)
  at oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:340)
  at oracle.jdbc.driver.PhysicalConnection.<init>(PhysicalConnection.java:553)
  at oracle.jdbc.driver.T4CConnection.<init>(T4CConnection.java:254)
  at oracle.jdbc.driver.T4CDriverExtension.getConnection(T4CDriverExtension.java:32)
  at oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java:528)
  at java.sql.DriverManager.getConnection(DriverManager.java:571)
  at java.sql.DriverManager.getConnection(DriverManager.java:215)
  at com.ptc.wbm.worm.core.SourceCrawler.getConnection(SourceCrawler.java:306)
  at com.ptc.wbm.worm.core.SourceCrawler.caseOneAndThree(SourceCrawler.java:248)
  at com.ptc.wbm.worm.core.SourceCrawler.enable(SourceCrawler.java:232)
  at com.ptc.wbm.worm.core.WormModelAdapter.initialize(WormModelAdapter.java:366)
  at com.ptc.wbm.worm.core.WormModelAdapter.<init>(WormModelAdapter.java:266)
  at com.ptc.wbm.worm.core.WormModelAdapter.newWormModelAdapter(WormModelAdapter.java:1203)
  at com.ptc.wbm.worm.core.WormModelAdapter.newWormModelAdapter(WormModelAdapter.java:1191)
  at com.ptc.wbm.worm.core.WormModelAdapter.newWormModelAdapter(WormModelAdapter.java:1167)
  at com.ptc.wbm.sysgen.SysGen.main(SysGen.java:406)
12:42:16 ERROR ui.SysGenUXHandler            -
################################ !!! ERROR !!! #################################
# An Exception/Error occurred during execution with the following message      #
# [Message: Connection refused: connect]                                      #
# Please check the logs at C:\WC\apps\ptc\Windchill\wbm\sysgen\20160524123915\ #
# logs for additional info.                                                    #
12:42:16 INFO  sysgen.SysGen                 -
  Session Summary:
  XML Generation: 10 seconds
  Total elapsed time: 178 seconds.
  Session State: FAILED <<<< ERROR !!!
mgupta-2
6-Contributor
(To:sghongade-2)
Dear Shravan
This error is because WBM is not bale to connect to Staging DB to populate the WBM schema (requires tables/indexes etc).
See if you can connect to your staging DB from command prompt, also verify the DB entries in site.xconf.
Mahesh Gupta
