I like using the Dragger when creating a section View... but it is often off-screen. The arrow shows up in the middle of the assembly but I'm usually zoomed in to a specific area.
Can I get the Dragger to pop up at my cursor location?
Same goes for the Assembly Component Dragger.
Yes, click the Tri-Ball icon. It allows you to move the location.
