2d drawings using Windchill mobile
jgronwick
3-Visitor
Is it possible to view 2D drawings (.plt) using Winchill Mobile? If not, what is the best way to view .plt files from Windchill on an iPad?
right now we're looking at a custom cad worker to convert autocad to pdf. then place the pdf as the default representation of the object. WE're exploring this right now. DWG Converter - Batch Convert DWG to PDF,EPS,CGM,SVG,PLT,TIFF... due to the command line support. With any luck we should be done Friday.
mbarbosa
6-Contributor
(To:sknox)
Hi Steve,
I'm not sure if I understood, PTC will use DWG Converter?
