We are happy to announce the new Windchill Customization board! Learn more.
Export Organization
ailut
Export Organization
Hi all,
Do you know if its possible to export the organization in Windchill 10.2?
Alex
satre-2
(To:ailut)
Alex,
Do you want to split one windchill installation with 2 or more organization into separate windchill installation? or you want to migrate one organization unit to other PLM system ?
Below are the several approached I used in past
  • Windchill bulk migrator is best tool to extract data for Extract data and migrate into other windchill. In staging database of WBM you can perform necessary data clean-up/normalization also,
  • If you have good knowledge about Windchill API’s then it would more simple to write custom java classes which will query and extract data from windchill.
  • OOTB you can use export and import manager to export data from windchill  (Context > utility > Export  Import Manager  )
Hope it helps  !!!
Shryeas
