Pro-nc , how to enable machine play option
Here's a link to Library of Basic Machine Assemblies => https://support.ptc.com/appserver/wcms/standards/ssl/freefull_cskdb.jsp?im_dbkey=98152
And the rules to create one : http://support.ptc.com/cs/help/creo_hc/creo10_hc/index.jspx?id=rules_for_creating_a_machine_assembly&action=show
You probably have to define a machine assembly through this window below (definition of the working center):
You must have an assembly corresponding to the machine you use. This is the problem. You have to find one or build it by yourself. If you look to Creo help you will find what constraint you have to respect in order to work correctly.
