We are happy to announce the new Windchill Customization board! Learn more.
Standard Alphabetic Versioning Scheme
aachanta
Hi All,
Can you please answer below 2 questions on Versioning Scheme ?
1. ) Can I use an Alphabetic Versioning Scheme for a sub type object and a Numerical Based Versioning Scheme for its parent object ? Like to elaborate it, I want to use Numerical Versioning Scheme to "WTPart" and Standard Versioning Scheme to its sub type "CustomPart" ? Is it possible in Windchill ?  Can you please let me know about it once ?
2.) If I am using a Standard Alphabetic Versioning Scheme for both WTPart and its subtype CustomPart and if I dont want to use or skip the characters like A, D, G, I, K, L, M etc. only for its subtype CustomPart but not for WTPart. How would I do that ? Can you please let me know about it once.
Can you please brief me on these two queries.
Thanks in advance.
Best Regards,
Aditya Achanta
Aditya,
You can create two separate OIR for WTPart and custom Part and In OIR mention which version series you want to use for each type.
    <!--  set the version info to a generated version info -->
<AttrValue id="MBA|versionInfo" algorithm="com.ptc.core.foundation.vc.server.impl.VersionInfoGenerator">
<Arg>wt.series.HarvardSeries</Arg>
</AttrValue>
If you are using file based series then you can add legacy=true in series to skip the latters if you can specify skip list in wt.properties using below properties  wt.series.MulticharacterSeries.MilSpec.skipList
Hope it helps !!!
Shreyas
9405954712
Aditya,
</AttrValue>
Hope it helps !!!
Shreyas
9405954712
aachanta
(To:satre-2)
Hi Shreyas,
Thank you.
Upon adding the characters that are to be excluded in the skiplist will that be reflected for all objects ?
Like as I said i want few characters to be skipped only for CustomPart but not WTPart. So will this be skipped for WTPart as well ? Can you please let me know about it once.
Best Regards,
Aditya Achanta
