how to find the matrix element that contains the minimum or maximum value in the matrix?
rdelascasas
6-Contributor
Obtaining the minimum and maximum value in a matrix is easy due to you can use the functions min and max.
but i need to obtain the matrix element that contains the minimum and maximum value inside the matrix.
Thank you in advance,
Rogelio
Hola Rogelio. Muy buenas tardes.
Alvaro.
Alvaro.
RichardJ
(To:rdelascasas)
Sorry, but your question is not clear. Does this answer it?
If not,please clarify what you are looking for.
rdelascasas
6-Contributor
(To:RichardJ)
Alvaro and Richard,
thank you very much for your answers, both are correct!!!
but i could only marked one as correct.
one more questions, where in the help i can find this type of responses?
Best regards,
Rogelio
Thanks! Actually, Richard have too many points!
This kind of brief solutions can be obtained from mathcad's electronics ebooks, but don't know in prime versions where are they. That's include, for example, some very old versions of mathcad, like smath (believe, can't remember the name very well) with solutions for high school problems, or the Schaum series, solved in mathcad. Recently, I see a pdf with the teacher solutions from an undergraduated textbook, all write in mathcad, 14 or 15.
Also, forum, even don't have very well search engine, can help, I think. Or use google "in-site" search engine too.
Best regards.
Alvaro.
Hola Alvaro,
Muchas gracias por tus respuestas.
donde podria yo encontrar ese documento en PDF que mencionas?
Yo trabajo directamente con Mathcad 15, tengo tambien Prime 3.1 pero Prime todavia esta muy lejos de darme los mismos buenos resultados que Mathcad 15.
Muchas gracias por adelantado,
Rogelio
Hola Rogelio.
El documento PDF, al ser las soluciones del problemario de un libro, es de circulación restringida, por decir algo. Los otros libros, son electrónicos y consistían en archivos de mathcad. Un ebook de mathcad es un archivo de texto que funciona como índice, de extensión hbk, y una carpeta con el mismo nombre que el hbk donde están contenidos todos los demás archivo en formato mcd.
Antes venían en diskettes con el libro en cuestión. Esa era la forma de distribuírlos de la editorial Schaum. El de circuitos eléctricos, vibraciones y termodinámica son algunos de los que aún conservo y empleo. Otros venían en la edición electrónica del libro, con alguna versión "reader" del programa, como por ejemplo el manual de ingeniero mecánico de Marks.
Ahora bien, también había otro tipo de libros electrónicos, como "Electrical solved problems", otro similar para progamación, ecuaciones diferenciales, y varios títulos más (arriba de 10), que eran editados por mathsoft, y se podían descargar desde la web de ellos. Esos ebooks tenían lo que estás pidiendo: mostraban cómo resolver problemas cotidianos con el software. Recuerdo como última actualización de ellos hasta la versión 13 de mathcad, pero de ahí en adelante la verdad no recuerdo bien, pues me quedé en la versión 11 de mathcad, como la que ocupo cuando preciso "hacer cuentas".
Espero esto haya servido de alguna orientación en la historia de este muy buen software.
Que tengas excelente día. Un abrazo.
Alvaro.
