Printing Mathcad 3.1
bsteiger
Why can't I Print my Mathcad 3.1 file to PDF file?
Prime does not offer that feature. You will have to use/install a pdf printer (e.g. the free PDF Creator) on your own.
DenisJaunin
Hello
Or you can use the XPS to PDF Converter.
Kind regards.
Denis.
http://www.micre13b.com/xps-to-pdf-converter.html
But what happens on your screen when you are trying to print? Which PDF printers you have installed on PC?
