smoothing with movavg creates offset ??
bsimpkins
6-Contributor
hi all,
i'm using prime 2.  when i smooth some data with the movavg function, the resulting data is offset by the size of the smoothing window.  in fact, even the helpcenter example on using moving average to smooth data shows this resulting offset!  but with no comment.  attached.
is this a bug or am i using movavg wrong?
Here is a suggestion for a symmetrical moving average window
The attached file is in P3 format, so your P2 will not be able to read it - therefor the pic.
WE
Neither of the two.
Its simply the way this algorithm works and its explained in more detail in the Data-Smooth-Example. Here the help clearly states
Note
Large window widths introduce a time lag.
The reason is that only values to left of the time value are used for calculating the average. You might consider writing your own routine using a synmmetrical window.
Or maybe "medsmooth" or "medfilt1d" (deprecated but still available; replaced by "medsmooth") are more suitable for your purposes.
WE
RichardJ
Note
Yes, a decidedly inaccurate statement, since it's obvious that any window width will introduce a time lag, it's just a question of how big a lag.
A trick you can use with smoothing functions like this is to reduce the window size, run one smooth, reverse the data, run a second smooth. The second smooth undoes the shift created by the first smooth.
WE
RichardJ
Here is a Savistsky-Golay filter (and a modified version of it that is marginally better). It is a pure convolution operation, and as such does not introduce a shift.
Also look up the ksmooth function, which uses a symmetrical kernel and therefore does not introduce a shift.
bsimpkins
6-Contributor
super!  the symmetric moving average works like a charm.
i'm looking at the savistky-golay versions as well.
