Limiting Search Results
sghongade-3
6-Contributor
Hello everyone,
wants to limiting the search results, i tried
Search results can be limited by configuring the following properties:
• com.ptc.windchill.search.queryLimit
• wt.pom.paging.snapshotQueryLimit
• wt.pom.queryLimit
change the above properties but could not restrict the search also change table size in preference management.
but i am not able to restrict the search result.
Thanks in Advance
In the Org or Site admin Preference Management there is a setting for this as well.  Under Tables.  Set the Size Limit.
