hur aktiverar man pipe funktionen i Creo?
Hi Reza,
You need to be in an assembly in order to access the Piping functionality, via Applications > Piping.
Amit
Translated via Google:
How to Enable pipe in the Creo 2
how to activate the pipe function in Creo ?
Hi Reza,
Amit
thanks it works .
you can not use the pipe under prt ?
That is correct, you cannot access the Piping functionality from part mode only assembly mode.
If you are looking for the Pipe feature (used to be in Insert, Advanced, Pipe in WF), it isn't in the ribbon, but you can find it with the command search.
