Hello All,
I recently switched to Creo 3 and when I run the AutoGEM mesher, the summary now has red elements along with the standard green. I've search help but can't seem to find an answer or I don't have access to the content. Could someone explain what the significance of the red is? It appears that red only occurs on tri elements and the green is on quad elements so I'm thinking it might be to discern between different elements types but I would like to verify that assumption.
Steven,
I just found it. There is a setting under system colors. I'll check this as what I learned today.
