about ptc mobile visualization strategy
xyan-2
2-Guest
does anyone know ptc 3D mobile visualization strategy now, we found creo mobile updated before three yeas ago, so depressing about it, jt2go is better solution for jt and support customization, More and more customers put forward 3D interactive needs of mobile devices.
BillRyan
(To:xyan-2)
I agree, this is frustrating.  It seems PTC is now focused on Vuforia view app.  Customer's switching to or unable to switch from the utilization of JT instead of the Creo File should be a concern for PTC....because that is what is happening.
In our case as an integrator, we have many 3D cad files created in Creo Parametric as Shrink-wrap files.  We are unable to view this type of surface geometry in Creo View mobile...and I'm pretty sure when Illustrate publishes the data for Vuforia the same issue will exist.  You would think at the very least that surface geometry available for viewing in Creo Parametric would be available in downstream applications.
sure, it seems vuforia view still not support pvz or 3cdi from creo illustrator, that's a bad news. we can undstand ptc strategy.
there are many customer have requirment from mobile 3D view and customer app like 3D EPC or 3D repair manual, SLM can support now.
we dont know what should we do.
