vendor access to requirements
phartwig
All,
     Does anyone have a recommendation on how to allow vendors access to our Integrity data?  We would like to grant approved vendors access to specific requirements only, hiding/preventing access to all remaining requirements, even within the same project.  My initial thought was to create a subproject for each vendor and add create the items in each of those projects, but I am concerned that this will become very complex as we add vendors and multiple vendors need access to some of the same data.
Thank you,
Paul Hartwig
Hello Paul,
your question is very interesting and I must say that within Integrity is not "the" solution that helps.
Primarily, our read restriction is by project: if you like to restrict data to be visible only by certain persons it has to be stored in a specific project.
In your case, this would mean that you have to branch all or parts of your document into such a specific project, and grant read access to the external party.
Recently, I implemented a more sophisticated approach where we grant field readability to users. This way you may hide e.g. Text content from users they are not allowed to see. Then still, the whole document structure will be visible to them. I also discussed the option to move documents into shared folders for review, and move them back into the base project structure when the review is ready. This may also support the "limited access" approach.
Finally, to avoid that someone sees any data from a specific type, you can use type permissions.
To summarize:
1) Project visibility  - limited to static groups
2) Type visibility - limited to static groups
3) Field/Data visibility - limited to static or dynamic groups
If you found another working approach already for you, I would be very interested in hearing it.
Volker
