Finding the constants of an ODE
isavu
Hello everyone,
I have the differential equation m∙x ̈+C∙x ̇+k∙x=0 and i know only the mass, do you know if there is a way to find the coefficients C and K? do you think this can be solved with odesolve if i declare some initial conditions?
16 REPLIES 16
StuartBruff
23-Emerald II
(To:isavu)
Iulia Savu wrote:
Hello everyone,
I'd be interested to see any answers to this showing how, but I don't think you can.  AFAICT, if you know the mass and initial values (eg, position, speed), then you will still need to know what C and k are to know how the system will evolve.  For example, if I attach a weight to the bottom of a (massless) spring, and pull it down, then I won't know how quickly the spring will pull it back up unless I know how strong the spring is.   You may have a chance if you know the final values as well, though.
Stuart
So how do I find C and k, given m, x(0) and x'(0), Valery?
Stuart
Two equs with two unknowns
Guess no! The two initial conditions were already used to derive the solution which Wolfram came up with.
You can't use them a second time. Those two equations would be true for any valid value of k an C.
Its like Stuart already said - mission impossible!
Werner
As Werner says, no. You start with a differential equation with 5 unknowns: you do not know x, x', x'', C, or k. Given two initial conditions you can turn that into a non-differential equation in three unknowns: at a given t you do not know C, k, or x(t). Without more information, that is where it ends. It's not solvable.
isavu
(To:RichardJ)
And what do you think about the answers bellow? can i get real values for K and C if a have 4 initial conditions?
RichardJ
(To:isavu)
You don't need 4 initial conditions. Two initial conditions are enough to get rid of the derivatives, as Valery has shown (Mathcad can't do what Valery showed, but a solution is a solution ). Once the derivatives are gone, you just have an equation that is a function of t with two unknown constants. If you know the values of x(t) for any two times, t, then you can find C and k. So you need 4 conditions, but only two of them need to be "initial" conditions.
StuartBruff
23-Emerald II
(To:isavu)
I think there may be some confusion in the thread about what comprises an "initial" condition.
I assume that by an initial condition you mean some piece of information that is known at just one value of x rather than something that is known at some other value of x as well (eg, just x1, rather than x1 and x2)?
What 4 "initial" conditions do you think you might have?
Stuart
Numerical  and Symbolical (Wolfram) Solution with units - ???
Sorry, only so we can compare num and sym ODE Solutions with "units":
-MFra-
21-Topaz II
(To:isavu)
Knowing the general integral of the differential equation and some initial conditions, it is possible to determine the coefficients P and Q , in your case, C and k.
isavu
(To:-MFra-)
So i need to use the case of real roots, because i need real values that are going to be used later as parameters, and i don't understand how am i going to extract the values of c1 and c2 . Do i use the initial conditions? Because i don't think that's going to work...
-MFra-
21-Topaz II
(To:isavu)
Hi Iulia,
you need four initial conditions:
If you know as initial conditions even the first derivatives, then the road to the solution is a bit different.
Hi Lulia.
You can combine an Odesolve block with a Find one.
Best regards.
Alvaro.
Thanks, Alvaro!
Yes - "Two equs with two unknowns" - see above.
But better in Prime with units: m:=4 kg etc
