Assembly Grayed Out when Part Activated
kdirth
20-Turquoise
When a part is activated (or a feature is edited) the rest of the assembly is made transparent gray.  Is there a way to keep the solid colored view.
I am trying to create a routed cable and this makes it hard to place points for the sweep to follow.
TomU
(To:kdirth)
Change this in your config options:
TomU
(To:kdirth)
kdirth
20-Turquoise
(To:TomU)
Thanks, I changed the option to "never" and the entire assembly remains shaded.
