How to create Toolkit dll application as COM Visible?
PARTHIBAN_K
I want to refer the Toolkit dll application in my C# Project. So I want to make it COM Visible. Any Idea's
Parthiban Kannan
href="https://www.linkedin.com/in/parthiban-kannan/" target="_blank"
TomasLoun
(To:PARTHIBAN_K)
You don't need to create COM interface to use application in C#. It is better to create managed interface to .NET - An Overview of Managed/Unmanaged Code Interoperability
We already have our library with many Pro/Toolkit functions which we are using in C#
TomasLoun
(To:PARTHIBAN_K)
Hi Tomas,
I have tried many ways. I have created Win32 application executable file it is working fine.
But I am planning to create dll file for my C Sharp Project. Whenever I Calling my DLL in C# Project I am getting the below Error. May you help in this situation?
Error10error LNK2019: unresolved external symbol _ProEngineerConnectionStart referenced in function "public: __thiscall myClass::myClass(double,double)" (??0myClass@@QAE@NN@Z)C:\TOOLKIT DEVELOPMENT\ASYNCHRONOUS APPLICATIONS\TEST 4\AsyncTestDll\AsyncTestDll\AsyncDll\main.objAsyncDll
LOG FILE :
main.obj : warning LNK4075: ignoring '/EDITANDCONTINUE' due to '/INCREMENTAL:NO' specification
     Creating library C:\TOOLKIT DEVELOPMENT\ASYNCHRONOUS APPLICATIONS\TEST 4\AsyncTest4\Debug\AsyncDll.lib and object C:\TOOLKIT DEVELOPMENT\ASYNCHRONOUS APPLICATIONS\TEST 4\AsyncTest4\Debug\AsyncDll.exp
main.obj : error LNK2019: unresolved external symbol _ProEngineerConnectIdGet referenced in function "public: __thiscall myClass::myClass(double,double)" (??0myClass@@QAE@NN@Z)
main.obj : error LNK2019: unresolved external symbol _ProEngineerConnectionStart referenced in function "public: __thiscall myClass::myClass(double,double)" (??0myClass@@QAE@NN@Z)
C:\TOOLKIT DEVELOPMENT\ASYNCHRONOUS APPLICATIONS\TEST 4\AsyncTest4\Debug\AsyncDll.dll : fatal error LNK1120: 2 unresolved externals
Parthiban Kannan
Hi Tomas,
Finally my DLL works fine with C Sharp Application...
Parthiban Kannan
Hi Parthiban Kanna
Can you please guide me how you have achieved the same?
TomasLoun
(To:yshinde)
Yes, have you already started with the article I have mentioned?
PARTHIBAN_K
(To:yshinde)
Hello Yogesh,
         SImply I have exported dll using extern "C" in toolkit coding & directly loaded it into my C# Program instead of add reference method
Parthiban Kannan
TomasLoun
(To:PARTHIBAN_K)
Can you post how your makefile looks like? You have probably some problem in linked libraries...
Hi Tomas,
    I have moved to win32 dll application instead of makefile project.
Parthiban Kannan
