Please solve the calculation
ranto
9-Granite
alfa = 21.0375
please clarify, how two solve the first 2 calcualtion
Fred_Kohlhepp
23-Emerald I
(To:ranto)
The parenthesis in your equation is incorrect
Dear Sir,
The equation is correct. see given below.
However based on the below calculation , the result was not came , while calculating manual the result was came.
while link the vale of "x" from below formula, then only the out put is incorrect. think some unit problem.
x1, x2, x - no unit as per the calculation P=14.7 psi, Ss:20000 pi, E :1.0 no unit.
Please clarify
AndyWesterman
(To:ranto)
Dear Sir,
Thank your for your immediate reply. however i will check the unit considereation.
regards
Robert
vlehner
(To:ranto)
Robert,
look at this- hope it helps you.
Volker
