We have just installed Arbortext Editor v7, our first installation. When we try and open a 1.8 DM, we get a "dtd did not compile message", with the following explaination.
Can anyone help?
Please realise that we are NOT expert users…
In addition to Ray's advice, you might also want to consider contacting whoever supplied the S1000D doctypes to you. They may need to perform updates for compliance with 7.0 (or may already have a 7.0-compliant release for you). It doesn't appear you are using the PTC S1000D modules (which only support 4.0 and 4.1 of the spec).
You need to check with PTC as the directory for Markit in 7.0 is different than 6.1. In 6.1 there are two files ispudir, and ispudirp in the 6.1 market folder that do not appear in the 7.0 Markit. You need to put in a case for this, it could be an issue or a process change.
ray
We seem to (somehow or other) moved on from this problem onto another problem. The DTD will still not compile and we now get the following error message:
Warning: Could not locate DTD entity '%COMPS'
Public Identifier: '-//AECMA1-8/DTD/Comps.ent'
System Identifier: '(none)'
No entry was found for the above public identifier
in any of these files:
W:\cECS\Epoch\Test DTD\AECMA1-8\catalog
C:\Program Files\PTC\Arbortext Editor\doctypes\catalog
Dtgen.exe Parser Error:
While parsing file W:\cECS\Epoch\Test DTD\AECMA1-8\DTD\descript.dtd:
Unknown parameter entity name (AECMA) used in reference.
If name is spelled correctly check that the entity declaration in the DTD
contains a PERO (e.g. %) symbol followed by a space
(err:623 line:73 pos:3874)
HELP!
Thank you for all your support.
It seems that we need an SGML plug-in so have requested this through our support contract.
I'm facing the same problem, what SGML plugin was it, and where did you get it?
Thanks!
